vincent
Toyo T1-R Le remplacant du Toyo T1-S.
http://www.toyo.co.uk/index.php?fuseaction=car.t1-s
MKIII 1DO
Posté le: 28 Juin 2004 14:50
KARLUS
marche pas pour moi.....sorry
_________________ Quelque soit boisson tu m'a donné donne moi du rhum pour l'arroser!
Posté le: 28 Juin 2004 18:21
vincent
marche bien chez moi!
MKIII 1DO
Posté le: 29 Juin 2004 10:04
KARLUS
bizarre ca......j'ai un 404
pas grave alors
Posté le: 29 Juin 2004 10:06
Qupder
T1-S
T1-R
Proxes T1-S Specifications
Looking for high performance?
Your search is over.
To get the best from your car and to enjoy your driving to the full you need a tyre designed and manufactured to exacting standards - namely the Toyo Proxes T1-S. With its silica-enriched rubber compound, the Proxes T1-S gives outstanding roadholding and control in the dry or the wet. This tyre also has low noise levels, gives good ride comfort and is long lasting as well as looking aggressively stylish on all cars.
Available in 67 different sizes
currently, this will reduce to 12 as Proxes T1-R is introduced.
Proxes T1-R Specifications
What do you do when you make the best performing tyre in the wet?
You start again and make a better one!
That's what's happened with the new Proxes T1-R, the new, natural choice for enthusiastic drivers. The Proxes T1-R boasts a special performance compound and tread pattern which gives incredible road holding in all conditions, especially in the wet. The V-shaped grooves in the tread pump water away allowing the rubber to grip the road.
These are bounded by circumferential grooves which allow the Proxes T1-R to give you even better wet grip whilst being quieter and longer lasting as well. And, whilst practical, these design elements also makes the tyre look spectacular on any car.
The Proxes T1-R is introduced in a range of the most popular high performance sizes.
It will increasingly cover more sizes from 14" up to 20" and beyond as further sizes are added.
Proxes T1-R will gradually replace the Proxes T1-S to be the ultimate tyre for performance use.
ps: il y a aussi les tableaux mais si je fais un copier coller ca va etre illisible
Change de proprio
Posté le: 29 Juin 2004 11:55
KARLUS
cool merci
Posté le: 29 Juin 2004 15:29
Qupder
Karlus972 a écrit: cool merci
de rien
par contre jene me charge pas de la traduction car je ni comprends rien
Change de proprio
Posté le: 29 Juin 2004 15:41
KARLUS
par contre jene me charge pas de la traduction car je ni comprends rien [/quote]
je comprends tout, mais trop lazy pour traduire......
Posté le: 01 Juil 2004 13:14
cupra87
je traduis en gros pour toi qupder.. c est aussi performant que le T1 S mais un peu mieux sur le mouillé... remarque, le dessin global du pneu reprend les uniroyal ( reputés sous la pluie.. mais pour en avoir eu .. juste sous la pluie!)
Posté le: 01 Juil 2004 20:56
Qupder
merci cupra
ouai uniroyal c'est pas génial (pas une référence pour moi)
Change de proprio
Posté le: 01 Juil 2004 23:13
cupra87
bien d accord.. j ai eu d autres pneus plus efficaces sur le mouillé sans etre reputés pour ca.. notamment les T1S ou les bridgestone
Posté le: 02 Juil 2004 12:08
vincent
http://www.toyojapan.com/new_tires/index2_1.html
MKIII 1DO
Posté le: 20 Juil 2004 10:29
